hi,
The error below, occurs when I start the application:
There was a failure while initializing the Agent SVN source control provider. You cannot use this provider to perform source control operations.
Error Agent SVN
Hi Abdul,
Thanks for the bug report.
To help identify the issue could you try the following:
1) Start the Agent SVN configuration tool.
2) Turn on the Help debug the SVN configuration with extra logging option.
3) Start your IDE to replicate the issue you described earlier.
4) Go back to the Agent SVN configuration tool and use the ... button to acces the log file produced and send it to the e-mail address at the bottom of this posting.
The log file should help me determine what has gone wrong.
Thanks in advance.
Thanks in advance.
Also make sure you are running the latest Agent SVN version found here: http://www.zeusedit.com/agent/download.html
