# Name: Process
# Decription: Run a executable inside Zeus using Python and capture
# the output.
import os
import zeus
import subprocess
def key_macro():
# http://docs.python.org/library/subprocess.html
# set the current directory
os.chdir("c:/temp")
# initialise the startup info to run hidden
info = subprocess.STARTUPINFO()
info.dwFlags |= subprocess.STARTF_USESHOWWINDOW
info.wShowWindow = subprocess.SW_HIDE
# run a command and capture the output
p = subprocess.Popen(["cmd.exe", "/k", "dir *.*"], stdout=subprocess.PIPE, startupinfo=info)
result = p.stdout.read()
p.wait()
# display the output
zeus.message_box(0, result, "Python Process Output")
key_macro() # run the macro
