Are there plans for adding support for google Dart in the near future?
Tom
support for google dart
Hi Tom,
But in the mean time it is fairly easy to add some level of Dart support to Zeus.
Just do the following:
1) Create a Dart Keywords File
Save the following details to the c:\temp\dart.zki file.
2) New Document Type
Use the Options, Document Types menu and create a new Dart document type.
These are the only two details you need to enter:
3) Import the Keywords File
In the keywords section of the document type create above import the c:\temp\dart.zki keywords file created earlier.
4) Code Folding
Open the xFolder.ini file and change this line:
to be this:
On Windows 7 the xFolder.ini file is found here:
On Windows XP the xFolder.ini file is found here:
5) Setting up the Compiler
Finally edit the Compiler section of the document type to run the dart2js utility.
I will look to add a Dart document type to the Zeus installer.Are there plans for adding support for google Dart in the near future?
; Zeus Keyword Information File
; NOTE: To correctly import this file make sure it has a .zki file
; extension.
[Syntax]
CommentStart01=/*
CommentEnd01=*/
NestsComments01=No
LineComment01=//
CommentStart02=
CommentEnd02=
NestsComments02=No
LineComment02=
Delimiters=#~!@$%^&*()[]{}<>=+/?|;:-,.
DelimitKeywords=No
IgnoreCase=No
Literal=\
ManageComments=No
Numbers=(0x*[0-9A-Fa-f]+[Hh]*)|([0-9]+(L*))
Preprocessor=#
Strings="'
TripleQuotes=No
[ReservedWords]
break
case
catch
class
const
continue
default
do
extends
false
final
finally
for
if
in
is
new
null
super
switch
this
throw
true
try
var
void
while
[ExReservedWords]
Pattern=
IsNested=No
[UserWords1]
bool
double
int
String
[ExUserWords1]
Pattern=
IsNested=No
[UserWords2]
[ExUserWords2]
Pattern=
IsNested=No
[UserWords3]
[ExUserWords3]
Pattern=
IsNested=No
[UserWords4]
[ExUserWords4]
Pattern=
IsNested=No
[UserWords5]
[ExUserWords5]
Pattern=
IsNested=No
Extensions: dart
Description: Dart Document Type
4) Code Folding
C/C++=c;cc;cpp;cxx;c++;h;hh;hpp;hxx;h++;ox
C/C++=c;cc;cpp;cxx;c++;h;hh;hpp;hxx;h++;ox;dart
C:\Users\Jussi\AppData\Roaming\Xidicone\xFolder\xFolder.ini
C:\Program Files\Zeus\xFolder.ini
