zeus 3.97i open file from cmdline bug
gwgs
Post by gwgs »
Since the upgrade when i open a file from the cmdline, it opens a blank version of the file. If I open the file with the open dialog it opens correctly
Grant
gwgs
Post by gwgs »
seems to be trying to open up the filenames passed in as if they're located in the root of C: drive, not the current directory where zeus was called from.
so I get C:\test.py instead of d:\source\test.py
gwgs
Post by gwgs »
also not opening files if wildcard in filename specified
gwgs
Post by gwgs »
backup files also get written to C:\ even if you provide the path\filename from the cmdline
The command line parsing code was changed to fix a bug reported by another Zeus user. That change introduced this new bug :(
This bug should be fixed in this beta: http://www.zeusedit.com/z300/ze397j-beta.zip
gwgs
Post by gwgs »
Problem still occurring :(
Grant
gwgs
Post by gwgs »
more information, if you start zeus from the cmdline it gets the filename/path incorrect.
if you call zeus from the cmdline when it is already open, it will open the file correctly
eg:
zeus test.py
doesn't work
zeus
zeus test.py
does work
It is working fine at this end. Make sure you are in fact running the latest beta version.
For example a dir g*.txt of the c:\temp folder results in this output:
      Zeus for Windows Programmers Editor - Version 3.97j - beta
      Copyright (c) Xidicone P/L 1993-2012.  All rights reserved.
 Volume in drive C has no label.
 Volume Serial Number is D8DC-6971
 Directory of C:\temp
13/08/2011  08:20 PM             1,112 gm.txt
25/01/2012  08:11 PM             4,275 good.txt
               2 File(s)          5,387 bytes
               0 Dir(s)   2,459,774,976 bytes free
At the c:\temp folder command line prompt this command:
C:\temp>zeus good.txt
works with or without Zeus running.
gwgs
Post by gwgs »
Definitely v3.97j beta.
New info:
It works for anything opened on C: drive, but not for files opened on any other drive
eg:
C:\python27\readme.txt works
D:\pythonsource\readme.txt doesn't, just opens a blank file of C:\readme.txt
Hope this helps
Grant
This bug should be fixed in the latest beta: http://www.zeusedit.com/zforum/viewforum.php?f=6
gwgs
Post by gwgs »
Yup that worked. Thanks Jussi
