block cursor
mark4th
block cursor
Post by mark4th »
a micro thin vertical bar hiding between two characters is visually less prominent than a block cursor. maybe its my ye olde dos days poisoning my opinion but i much prefer a block cursor to a I beam.
would be a nice option!
p.s. TYTYTY for NOT enforcing a schizophrenic jitterbug cursor! virtual space ftw :)
It's possible to change the shape of the cursor via the INI file ;)
To do this locate the zeus.ini file, edit it with notepad, add the following details and then start Zeus:
[Caret Options]
CaretX = 16
CaretY = 8
CaretInsertX = 16
CaretInsertY = 16
