Don't debug lines with %n
E Programmer
Post by E Programmer »
Jessie
I have associated this macro with my ~ key.
Lua Macro:
  local data_line=get_line_text()
  debug_output("line"..data_line)
key_macro()
When I select this line from a file:
Data%n
Zeus crashes (I lose unsaved work).
If the line is
Data%m
it's ok. It seems to be the characters '%n' that does it.
It does not crash if I don't have the debug_output in the file. So once my files are working, everything is fine after I remove all the debug_output lines. So this is a NON-CRITICAL bug. More of an FYI
I'm using Zeus 3.97-beta25
The bad news is I can confirm this is a bug and a very serious one at that :(
The good news is I can replicate the error so it should be fixed shortly ;)
This bug has been identified. The issue is the %n pattern is being identified as a format character.
The short term fix is to write the macro as follows:
  -- %n is picked up as a format character so de-format it when found
  if (string.find(data_line, "%%n", 1, false) ~= nil) then
    data_line = string.gsub(data_line, "%n", "%%n")
    --message_box(1, data_line, "Testing")
key_macro()
Shortly, there will be a new beta version released that also fixes this issue.
This issue should now be fixed in the beta version found here:
http://www.zeusedit.com/z300/ze397h-beta.zip
