line cursor transparency
bsuggo
Post by bsuggo »
Is it possible to set the line cursor colour so that it colours the back groung only? This would allow all your other foreground colours to still be visible when the cursor is on a line not all the same colour, similar to Crimson editor.
This feature was in fact added quite a few Zeus version ago.
What version of Zeus are you running running :?:
bsuggo
Post by bsuggo »
Hi Jussi
The version is 3.97e
That version should be fine. I suspect you just need to edit the color settings.
To do this just edit the document type and in the Coloring section, select the Line Cursor option and set the colors to suit.
NOTE: Make sure you follow the tip text that get displayed when this option is selected ;)
bsuggo
Post by bsuggo »
Thanks Jussi :oops:
