Hi Jussi
I just updated to 3.97f and discovered this bug with templates. If you check the option "Expansion text is a filename", then after the template copies in the external file, it appends the following
This occurs with the all my macros which uses this feature.
Thanks!
Jack
problem with template using 3.97f
I created a simple test template that just imported a 5 line text file and it worked fine for me
But I am running the latest beta version found here: http://www.zeusedit.com/z300/ze397g-beta.zip
I would sugget trying out this latest beta version.
If that fails could you then try adding a new simple test template to see if that also fails.
The problem still exists with the beta. I discovered another simpler method to create a similar problem. I made a template I called test whose expansion text is is contained on 2 lines
"Expansion text is filename" is NOT checked.
With the cursor at the beginning of a line, I type
test followed by the space bar and I get
Hopefully, you can duplicate this.
Thanks!
Jack
Similar to but not exactly the same as checking "Expansion text is filename". I'm guessing this is a bug unrelated to
Thanks!
Jack
This bug should be fixed in the latest version found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
Both of these issue should be fixed in this versionSimilar to but not exactly the same as checking "Expansion text is filename".
