Page Scrolling Hides Matching Brace Highlighting
If I highlight a brace so that its matching partner is also highlighted and the partner brace is currently out of view, then scrolling the document will hide the brace highlighting as soon as the first brace goes out of view.
The issue here is that Zeus by design will always keep the cursor on the current screen.
So what has happened in this case is the initial scroll has left the cursor off the screen. The design feature described above has then moved the cursor back onto the screen, which in turn has removed the matching brace indication.
Here you go Jussi...
In the code example below, just move the caret until the top brace is highlighted, then scroll the page down either using the mouse wheel or by clicking on the vertical scrollbar down arrow.
As soon as the top brace scrolls out of view the brace-pair highlighting is "lost".
function Test()
This is what I see.
When the cursor is on the brace the matching brace is shown.
If the cursor is on the bottom brace and the top brace is scrolled off the page the highlight is retained.
If the cursor is on the top brace and it is scrolled off the page then the highlight is lost.
This is by design.
As I said earlier, the in the last case the action of scrolling the page has moved the cursor off the brace so naturally there is no longer a matching brace.
Ok understood...
In that case therefore, I would humbly suggest that the caret position should be retained when it is scrolled out of view. This seems more intuitive to me and in any case finding a matching brace using highlighting won't work when the enclosed block exceeds the visible page region.
Note: A quick survey on my workstation indicates that the majority of editors seem to work this way, (i.e. retaining the caret position out of view). This includes NetBeans, SciTE, Notepad, Wordpad, MS Word, LibreOffice Writer and Notepad++, but not CodeWright.
