"Find in Open Files" and "Find in Project Fil
Does Zeus have a "Find in Open Files" and "Find in Project Files" option somewhere?
No. There is only a Replace in Open Files option in the replace dialog.Does Zeus have a "Find in Open Files" and "Find in Project Files" option somewhere?
Having said that, you could get the list of files using the get_window_count, get_window_id, get_window_name macro functions.
The project file information can also be got at via a script using the projects, project_files macro functions. There is already a projects.lua macro that shows how to uses these functions.
So with a list of files it should be easy enough to write some additional macro code that runs xfgrep.exe to do the file searching and have the results show up in a tool window, not unlike the current Find in Files menu.
