I would like to be able to drag and drop files from one folder to another in the workspace view's project tree. At the moment I have to remove the file from the project and then re-add it in the target folder.
Of course I may be missing something obvious... please let me know in that case.
Keith.
Dragging and Dropping Files into Folders in the Workspace
A quite easy option for doing this is:
1) Activate/open the file you need to move; and
2) Right - Click on the target folder in your workspace where the file needs to be moved to, then choose the option "Add Current File to Folder";
3) Right - Click on the folder where the file should not reside and then choose "Remove File from Project".
You have successfully completed the move at this point.
