Search doesn't look in folded text
Rat
Post by Rat »
I'm not sure if this is the intended functionality or if its a setting that can be changed, but currently Zeus ignores (almost all) folded text when conducting searches?
I am not seeing this. For example consider this code:
    public SomeCode()
        FindMe();
Closing the fold point and then searching for the FindMe text results in the fold being opened and FindMe being highlighted.
Rat
Post by Rat »
Try collapsing all of the folds in the following HTML code example and then searching for "SomeText"...
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
 <head>
  <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
  <title>Search Test</title>
  <script type="text/javascript">
     var SomeText
  </script>
 </head>
 <body>
  Search Test
 </body>
</html>
Thanks for the bug report, I can now replicate this issue ;)
PS: I noticed from your sample piece of code that the last change to the XML folder has broken the folding of XML block comments :(
I have uploaded a new xFolder this fixes this: http://www.zeusedit.com/z300/xFolder.zip
Rat
Post by Rat »
Hmmm... XML folding seems to be broken still. See example below:
  <marker name="Marker 2">
   <information><![CDATA[<div>Some Test Text</div>]]></information>
  </marker>
Rat
Post by Rat »
Note: It was definitely working with XML after you posted the original CDATA fix.
I think it you are probably seeing an older cached version of the DLL zip file.
The timestamp off the dll file itself should be: 11/07/2011 2:247 PM
That timestamped dll is working for me.
Rat
Post by Rat »
Yep seems to be working ok on my workstation... must have stuffed up versions on my laptop.... Sorry.
This issue should now be fixed in the latest beta version 7 found here: http://www.zeusedit.com/z300/ze397g-beta.zip
Rat
Post by Rat »
If you fully collapse the following JavaScript code fragment and then do a case-sensitive whole word search for "SomeText" the program will find the word but won't open the folds enough to properly select it :(.
 This is a comment
 This is a comment
 This is a comment
 SomeText
 This is a comment
 This is a comment
 This is a comment
AnObject = function()
 this.Property1 = 0;
     This is a comment
     This is a comment
     This is a comment
     SomeText
     This is a comment
     This is a comment
     This is a comment
 this.Function1 = function()
  try
   this.Property2 = 0;
   return true;
  catch (e) {}
  return false;
 if (this.Function1()) {return this;}
 return null;
This issue should now be fixed in the latest version found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
Rat
Post by Rat »
Very nice Jussi... works well here. I bet there were a few late nights in that release! ;)
