When I position the caret at the beginning of a line and press ALT-M then END to select the entire line, it doesn't select the terminating Carriage Return and Line Feed as Brief/CodeWright does. This means that when I want to select a whole line and then copy it I have to either include or add the CR/LF pair as a separate step.
Now I know this is a very minor issue, but I'm including it anyway, since copying lines is something I seem to do a lot of, and the extra typing does begin to add up...
Cheers,
Keith.
