--        Name: Matching Brace Select
--    Language: Lua Macro
-- Description: This Lua macro will select the region from the current
--              brace character to the matching brace character.
    if document > 0 then
        -- save the current cursor
        cursor_save()
        current = get_char_at()
        previous = '\0'
        if get_cursor_pos() > 1 then
            previous = get_char_at(get_line_pos(),get_cursor_pos()-1)
        -- position the cursor for the brace match that follows
        if current  == string.byte('(') or
           current  == string.byte('<') or
           current  == string.byte('[') or
           current  == string.byte('{') then
              MoveLineRight()
        elseif
            previous == string.byte(')') or
            previous == string.byte('>') or
            previous == string.byte(']') or
            previous == string.byte('}') then
              MoveLineLeft()
         MarkBlockSet()
         if BraceMatch() == 1 then
             -- ignore the saved cursor details
             cursor_ignore()
             -- see where we ended up
             previous = '\0'
             -- position the cursor inside the brace chracters found
                   MoveLineRight()
             elseif
                   MoveLineLeft()
             MarkBlockReset()
            -- restore the cursor as no matching brace was found
            cursor_restore()
            MarkHide()
        message("This macro only works for document files.")
