Thanks in advance.
Now to the issue at hand. Inside Zeus I used the Tools, DOS Command Line menu and ran this command to bring up the AStyle help page:AStyle.exe does not work using options: -A3 and -b
In the resulting help information I found these two entries:astyle -?
--style=k&r OR --style=k/r OR -A3
Kernighan & Ritchie style formatting/indenting.
Linux brackets.
So I think the issue you are seeing is the -b is part of the ANSI style and not the K&R style and hence the reason for the need to run the tool twice.--brackets=break OR -b
Break brackets from pre-block code (i.e. ANSI C/C++ style).
-- Name: Astyle Code Reformating Macro
-- Language: Lua Macro
-- Description: This macro will excute the astyle.exe utility to reformat
-- the current file. For more details on how to use astyle.exe
-- visit the following web page:
-- http://astyle.sourceforge.net/astyle.html
-- dialog box caption
local caption = "Astyle Utility"
local locked = is_read_only()
-- macro only works for named documents.
local named = is_named()
if (locked == 1) or (document == 0) or (named == 0) then
-- can't run astyle.exe on current document
message("This macro can only be run with a named, writable document file.")
local dir = macro_tag("$fdd")
-- the name of the backup document
local file_backup = file_name .. ".orig"
local message1 = "Astyle is ready to re-style the current file, while the following backup\nfile will also be created:\n\n '" .. file_backup .."'\n"
local message2 = "NOTE: Astyle is specifically designed to work with C, C++ and Java\nfiles, so if the styling does not work as expected use backup file to\nundo the changes made.\n\nDo you want to continue with the styling?"
local message_text = message1 .. "\n" .. message2
-- run astyle.exe on current document
local result = 6; --message_box(4, message_text, caption)
-- check for the IDYES return value
if (result == 6) then
message("Astyle is formatting the code....")
message("Operation canceled by user.")
-- Predefined Styling options:
-- --style=ansi
-- ANSI style formatting/indenting.
-- --style=kr
-- Kernighan&Ritchie style formatting/indenting.
-- --style=gnu
-- GNU style formatting/indenting.
-- --style=java
-- Java mode, with standard java style formatting/indenting.
-- --style=linux
-- Linux mode (i.e. 8 spaces per indent, break definition-block
-- brackets but attach command-block brackets.
-- --break-blocks OR -f
-- Insert empty lines around unrelated blocks, labels, classes, ...
-- --break-blocks=all OR -F
-- Like --break-blocks, except also insert empty lines
-- around closing headers (e.g. 'else', 'catch', ...).
-- --break-closing-brackets OR -y
-- Break brackets before closing headers (e.g. 'else', 'catch', ...).
-- --pad-oper OR -p
-- Insert space paddings around operators.
-- --pad-paren OR -P
-- Insert space padding around parenthesis on both the outside
-- and the inside.
-- --pad-paren-out OR -d
-- Insert space padding around parenthesis on the outside only.
-- --pad-paren-in OR -D
-- Insert space padding around parenthesis on the inside only.
-- --pad-header OR -H
-- Insert space padding after paren headers (e.g. 'if', 'for'...).
-- --indent-namespaces OR -N
-- Indent the contents of namespace blocks.
-- --indent-switches OR -S
-- Indent 'switch' blocks, so that the inner 'case XXX:'
-- headers are indented in relation to the switch block.
-- --indent-cases OR -K
-- Indent case blocks from the 'case XXX:' headers.
-- Case statements not enclosed in blocks are NOT indented.
-- --unpad-paren OR -U
-- Remove unnecessary space padding around parenthesis. This
-- can be used in combination with the 'pad' options above.
-- --keep-one-line-blocks OR -O
-- Don't break blocks residing completely on one line.
-- --keep-one-line-statements OR -o
-- Don't break lines containing multiple statements into
-- multiple single-statement lines.
-- --align-pointer=type OR -k1
-- --align-pointer=middle OR -k2
-- --align-pointer=name OR -k3
-- Attach a pointer or reference operator (* or &) to either
-- the operator type (left), middle, or operator name (right).
-- --convert-tabs OR -c
-- Convert tabs to the appropriate number of spaces.
-- ***** Option 1 Modify these options to suit *****
--local cmd_padding = "--pad-oper --pad-paren-out --unpad-paren "
local cmd_padding = "--pad-oper " --pad-paren-out "
-- indent command line options (see above)
local cmd_indent = "--indent-namespaces --indent-switches --indent-col1-comments --indent-preprocessor "
-- break command line options (see above)
local cmd_break = "--break-blocks --break-closing-brackets "
-- other command line options (see above)
local cmd_other = "--align-pointer=name --keep-one-line-blocks --keep-one-line-statements --max-instatement-indent=79 "
-- build up the full command line option (see above)
local cmd_options = "--style=ansi " .. cmd_padding .. cmd_indent .. cmd_other .. cmd_break
-- get the tab size for the current document
local tab_size = macro_tag("$TabSize")
-- see if real tabs are to be used
local use_tabs = macro_tag("$UseTabs")
if (use_tabs == "true") then
-- add the tabs option
cmd_options = cmd_options .. " " .. "--indent=tab=" .. tab_size
-- add the spaces option
cmd_options = cmd_options .. " " .. "--indent=spaces=" .. tab_size .. "--convert-tabs"
local cmd = "astyle.exe" .. " " .. cmd_options .. " \"" .. file_name .. "\""
-- for debugging only
--message_box(1, cmd, "Command Line", caption)
-- System control values
-- 1 - save the document before running the program
-- 2 - capture any standard output generated by the program
-- 4 - capture any standard error generated by the program
-- 8 - ask for additional arguments
-- 16 - the program will use the MS-DOS command interpreter (ie. dir *.* etc)
-- 32 - wait for the program to complete (the ESC key will cancel the wait)
-- run command using the 'save' and 'wait for complete' options
local flags = 1+32
-- run the astyle.exe command
if (system(cmd, dir, flags) == 0) then
-- ***** Option 2 Uncomment these lines (untested) *****
-- local cmd = "astyle.exe -b \"" .. file_name .. "\""
-- message_box(1, cmd, "Option 2 Command Line", caption)
-- system(cmd, dir, flags)
-- reload the newly styled docuemnt
FileReloadCurrent()
-- get the current window id
local id = get_window_id()
-- build the name of the backup file
local backup_file = dir .. file_backup
-- load the backup file as well
if file_open(backup_file) == 1 then
-- re-activate the reformated file
window_activate(id)
-- some feedback
message("The styling of the document is now complete.")
-- had problems running the command
local error_msg = cmd .. "\n\n" .. "Error executing the 'astyle.exe' command!"
message_box(1, error_msg, caption)
As you can see from above there is no location specified in the command line.where is the astyle.exe file located that the script is using?
