hi jussi:
re: "find"not working
deleting zeus.ini worked. thanks!
re: mru list
you are right! if i "window/close" a file, it gets added to the mru list.
i seldom "window/close" a file, i click on the little "x", and then save? yes or no. in this case, the mru list does not get updated
likewise, if i "file/save" and then "x" the mru list is not updated.
don't worry about it!
re: spam
there is a spam blocker named "qurb" that some people, myself included, like.
it operates on a very simple principle: it "quarantines" any email that is not from an email address that you have approved.
then you can display the quarantined list and accept some and dump the rest to a folder named "qurb". i find that it easy to scan the list because it appears that spammers routinely use what appear to be randomized email addresses that are easy to recognize.
omer
"find" stopped working
hi omer,
I will do a little testing just to make sure there isn't a bug lurking in there somewhere.re: mru list not working
you are right! if i "window/close" a file, it gets added to the mru list. i seldom "window/close" a file, i click on the little "x", and then save? yes or no. in this case, the mru list does not get updated
Thanks for the tip. I will check it out.re: spam
