Consider the following snippet of PHP code:
class MyClass
// the constructor
function MyClass()
// the method
function MyMethod($gear)
MyClass test.php /^class MyClass$/; " kind:class line:2 language:PHP
MyClass test.php /^function MyClass()$/; " kind:function line:5 language:PHP
MyMethod test.php /^function MyMethod($gear)$/;" kind:function line:10 language:PHP
MyClass test.cpp /^class MyClass$/; " kind:class line:1 language:C++ file:
MyClass test.cpp /^function MyClass()$/; " kind:function line:4 language:C++ class:MyClass file: access:private signature:()
MyMethod test.cpp /^function MyMethod($gear)$/;" kind:function line:9 language:C++ class:MyClass file: access:private signature:($gear)
For example, the c/c++ tagger correctly identifies the MyMethod method belonging to the MyClass class, while the PHP tagger incorrectly sees the method as a function, no way related to the class.
Since Zeus uses the ctags output to populate the class browser and uses the class browser to manage the code completion and intellisensing, in the case described the PHP class browser information is wrong and as such the intellisensing will not work as well as it should
