I just want to adapt ZeusLite for my students. I am using BriefEx (but I don't think that there is the problem) and when I want to insert a Tab I hear a sound and get the message
TODO:'D:\work\apollo\Zfwfun01.cpp' at line 8108
No Tabulator is inserted.
Is that a bug or perhaps only a wrong setting at a place I didn't find.
Greetings
Herbert
Tab-Key in ZeusLite only beeps
Hi Herbert,
This sound like a wrong setting.
You need to edit the BriefEx keyboard map using the Options, Editor Options menu, Keyboard mapping panel and check to make sure the Tab key is bound to the Tab keyboard function.
But what is strange is I checked the Zeus LIte tab key on my machine and it was configured correctly ?)
I suspect the differenc is due to the fact that you are usig a dfferent keyboard driver to me (I use the US keyboard layout) so the mapping might need a bit of adjusting for your keyboard. Remappign the key to the Tab function should work
This message means that specific keyboard function is not yet implmented.
