code folding problems in fortran
jpsam
Post by jpsam »
This is my second day of evaluating your software and I like much of it does so far but there are some issues here concerning the folding.
1) Folding fails when the read statement contains the "end=99". The folding in this case takes place at the read statement.
2) Folding fails when the end of the routine is "endsubroutine solver" intead of "end subroutine solver", both these are valid fortran.
3) Folding also fails for the case-statement when "end select" is written as "endselect"
4) the if statement does not fold well with mutiple "else if". I replaced the xfolder.dll in my version of 3.95s but the problem is still there.
Sample code:
subroutine solver()
do while( string(1:1) /= "<" )
read(funit, fmt=*, ERR =99, end=99) string, value
if( data1 ) then
a = b + a
else if( data2 ) then
c = 9
else if( data ) then
d = 10
end if
enddo
close(funit)
99 continue
close(funit)
select case(x)
case(1)
a = 1
case(2)
a = 2
endselect
The Fortran code folding fixes have been made and the new xFolder.dll can be found here:
To install this new dll backup the current dll and replace it with the one contained in the zip file. The else if folding issue is not fixed by this new dll :(
A fix for this bug requires a change to the zeus.exe itself and as such the fix will need to wait for the next Zeus patch. A new patch will hopefully be available in the next few weeks :)
JpSam
Post subject: code folding problems in fortran
Post by JpSam »
Ok the problem seems to be solved except for the "else if issue:
The latest Zeus patch fixes this problem: http://www.zeusedit.com/forum/viewtopic.php?t=328
