LUA block comment
la_piaga
LUA block comment
Post by la_piaga »
zeus (i'm trying version 3.95p) doesn't hilight lua block comments "--[[" since it seems to ignore everything after the line comment "--".
You need to edit the Lua document type and in the Keywords section enter the following values:
Comment Start: --[
Comment End: ]]
Line Comment #1: --
With these values entered the following example code them seems to color the block comment and line comment sections correctly:
  -- this is a line comment
  document = is_document()
    This is a block comment
la_piaga
Post by la_piaga »
Since the lua highliter was already implemented I thought it was a flaw of the editor itself and didn't think of a lack of definition in the document type configuration.
Ok, adding the block comment operator it works ;)
Zeksie
LUA: Arrays are not comment blocks
Post by Zeksie »
I'm having an issue in LUA where double nested array references are also matching the end of comment and highlighting as block comment.
For example:
array[myVal[2]]
The ]] gets highlighted.
Thanks for the bug report. This will be fixed in the next Zeus patch ;)
This bug is fixed in the latest Zeus 3.96j patch found here: http://www.zeusedit.com/forum/viewtopic.php?t=1251
