Q1: How to enable word wrap? This means, when a string is longer then a zeus's window height, editor automatically cuts the string and places it on another string. This Q is about only reading and viewing, without source modification (instead of Q2 is about).
Q2: How to disable world wrap in Zeus? (This Q concerning editing functions, instead of viewing) I hate, when Zeus cuts my typed string and move it on another string. I only want, that editor just VIEW the wrap, but don't actually modifying typed text by wrapping.
In other words, i hate how the word wrapping work in Zeus, and i want to know, how to switch it to works like in others editors
Q3: Can i make fast searching like in *nix editors? (Nedit for example) I mean, when i mark the text and push F3(find next), i'll search the marked text instead of previous search. The same Q with marked text, about copying, replacement and other tips - Is any way to enable fast copying, fast replacement etc.?
Big Tnx!
A couple of questions about Zeus features
Unfortunately Zeus does not have a view word wrap featureQ1: How to enable word wrap? ....This Q is about only reading and viewing, without source modification (instead of Q2 is about).
Use the Options, Properties menu to bring up the document type details and in the General section turn off the Line Wrap option.Q2: How to disable world wrap in Zeus?
As I said before, there is no view wrap option in ZeusI only want, that editor just VIEW the wrap, but don't actually modifying typed text by wrapping.
Save the following text to the find_text.lua file in the Zeus zScript folder:Q3: Can i make fast searching like in *nix editors? (Nedit for example) I mean, when i mark the text and push F3(find next), i'll search the marked text instead of previous search.
if document == 0 then
-- NOTE: get the current word or marked area
local text = macro_tag("$WEX")
if string.len(text) == 0 then
message("The cursor is not over a word!")
-- set the search text
set_find_text(text)
-- run the find for this text
SearchNext()
There are plenty of macro examples on this forum and in particular here: http://www.zeusedit.com/forum/viewforum.php?f=10
There are also more scripting examples found in the Zeus zScript folder.
