Replace command (replace using a backspace)
jay
Post by jay »
Is there an option to replace characters with a backspace ?
Example Input:
This is 01 text.
This is 02 text.
[do some replace command to find the numbers "0" and replace it with a backspace to result in ...]
Output:
This is 1 text.
This is 2 text.
Hi Jay,
In general, depending on the shape of the text being changed Zeus offers several ways to manipulate the text including a keyboard macro script, a search and replace or maybe even a column cut and copy.
But in to answer your question to convert this text:
This is 01 text.
This is 02 text.
into this text:
This is 1 text.
This is 2 text.
using a Search and Replace this is what I would do:
  1. Select the Edit Replace menu
  2. Enter this Find text (0)([0-9]+)
  3. Enter this Replace text \2
  4. Check the Use regular expression option
  5. Click the Replace All button
For more details on how to better understand the search string that I used use the Help, Help Contents menu and click on the User Manual, Regular Expressions section.
