text document editing
vinnie9000
Post by vinnie9000 »
I'm really new to this program & am using it on the advice of a programmer friend. I am trying to edit a 140MB txt file (2.5 million lines). I've opened it and keep starting the process of copying some of the necessary lines (approx 500,000) and moving them to another tab, but every time I grab 10,000 lines or more, the program seems to become non-responsive. Is there a better way of using Zeus or even another program designed to do what I am trying to do? Thanks in advance for any and all help.
Since Zeus is really a programmer's editor it was not really been designed as a very large file editor.
As a test I created a 120 Meg file:
c:\temp>dir big.cpp
Volume in drive D has no label.
Volume Serial Number is FAE3-1040
Directory of d:\temp
4/08/2009  13:51       129,021,480 big.cpp
              1 File(s)    129,021,480 bytes
              0 Dir(s)  54,933,577,728 bytes free
This was my experience editing this file in Zeus:
  1. The big.cpp file contained 4,175,640 lines of code
  2. It took about 10 seconds to load the file
  3. It took about 8 seconds to make a change and save the file back to disk
  4. It took about 3 seconds to close the file
  5. It took less than a second to copy 10,000 lines of marked text from the document to the clipboard
  6. It took less than a second to paste the text into a new tab
  7. The keyboard input was sluggish
So I had no troubles performing the task you descibed :) but the keyboard was definitely sluggish :(
Since Zeus loads the file into memory the level of responsiveness will vary a lot depending on the amount of RAM on the machine. In my case the machine was running Windows XP and had 4 Gigs of RAM.
A better option might be be to find a very large file editor as these editors have been specifically designed for editing large files.
I've heard Vim or Emacs can do this but I am not sure :?
PS: Which version of Zeus are you running and how are you marking the 10,000 lines of text :?:
The sluggish keyboard behaviour described above has been fix in the latest version of Zeus ;)
The latest version can be found here: http://www.zeusedit.com/forum/viewtopic.php?p=5306
