Export and import of key mappings
martinlooker
Post by martinlooker »
Is it possible to export the BriefEx keymappings and re-import them under a different name ?
If so could you explain step by step ?
Or is this just a backup and restore option ?
I've been trying to do this and struggling, I want to adapt the BriefEx mapping to my own use rather than starting from a blank mapping.
(Oh and thanks for your patience answering all my questions recently.)
Is it possible to export the BriefEx keymappings and re-import them under a different name?
Yes.
If so could you explain step by step?
  1. Options Editor Options menu
  2. Goto Keyboard Mappings panel
  3. Select keyboard map to be exported
  4. Hit export button and save map to text file
  5. Type in new keyboard mapping name
  6. Hit import button to import previously exported keyboard file
The export file is just a text file, so it can be edited in any text editor.
