Second Align Text macro
This script is based on the oriiginal align text macro: http://www.zeusedit.com/forum/viewtopic.php?t=2439
For example assume you code looks like this where | is used to indicate the cursor location:
        Some |            text
        that      is
        all    over
        the           place
Putting the cursor at the | location and running the macro four times gives you the nicely aligned code shown below:
        Some text
        that is
        all  over
        the  place
This script builds on the original by allowing the user to column mark a range of lines and have all marked lines aligned in the one go.
--        Name: Align  Macro
--      Author: Omer Kircher
-- Modified By: Jussi Jumppanen
--    Language: Lua Macro
-- Description: This function facilitates lining up columns of text.
--              To use, load the macro (i.e. F9 key), position the cursor
--              and then run macro using the Macro Execute (i.e. F8 key)
--              Alternatively you can bind the macro to the keyboard.
--              This version also lets you do several lines by just using
--              the column marking to mark all the lines that need to be
--              aligned.
--              Blank spaces between the cursor and the next word will
--              be deleted.
--              The cursor is then moved to the next line ready for
--              another operation.
    local locked = is_read_only()
        beep();
        return;
    -- default to the current line
    local top   = get_line_pos()
    local range = 1
    -- save the current cursor
    cursor_save()
    local marked = is_marked()
    if marked == 1 then
        top   = get_marked_top()
        left  = get_marked_left()
        range = get_marked_bottom() - top + 1
        -- move to the fist line of the marked text
        set_line_pos(top, left)
        -- remove the markings
        MarkHide()
    end -- if
    -- allign the lines selected or the current line
    repeat
        -- look for a white space (32) ascii character
        if get_char_at() == 32 then
            -- remove the white space
            MarkColumnToggle()
            MoveWordNext()
            MarkDeleteEx()
        -- position the cursor on the next line
        MoveLineDown()
        range = range - 1
    until range == 0
    -- restore original cursor
    cursor_restore()
    if marked == 0 then
        -- for the unmarked case position the cursor on the next line
        MoveLineDown()
    end -- if
