Open Files Auto Archive
mgag
Post by mgag »
It would be nice to gather all the open files and store them in an archive - like a poor man's version control. Often one will try different solutions to a problem and as you move from one to the other, it would be nice to be able to save them, as a group (if more than one file which is typical).
I would envision something that could take all the current open files and store them in a zip file, with any kind of name, that auto increments each time, and/or some way of attaching a small message to store with the files as a note. So like you hit the key/menu item and a small window pops up with a text section, and the current defaults for the filename and location, and a OK/Cancel button.
Then later the person can use look at the zip files which will list the contained files - this is better than having a lot of files hanging around.
mgag
Script
Post by mgag »
OKay so I am trying to write a script for this. Python is the target language. My attempt is below, but its not working and I may be going about this the wrong way. I thought I would jump from tab to tab and copy the contents of each file to a new file and save it.
1. Why don't I see the "print"s in the Maco debuging window (when I don't call screen_update_disable() )?
2. Once I have the text selected and copied, how can I save it into a file without having a dialog box appear? I tried passing the filename to MarkWriteToFile() but it doesn't accept a file.
import zeus
output_dir = "e:\\test\\"
print "Start"
zeus.screen_update_disable()
file_list = []
i = 0
while zeus.get_file_name() not in file_list:
    file_list.append(zeus.get_file_name())
    print "%d file:%s" % (i,file_list[i])
    zeus.MoveDocumentStart()
    zeus.MarkBlockToggle()
    zeus.MoveDocumentEnd()
    zeus.MarkWriteToFile("e:\\test\\mg1" )
    zeus.WindowNext()
    i+=1
zeus.screen_update_enable()
mgag
Script
Post by mgag »
Here is a better attemp, but still have a problem. zeus.get_line_text() is returning an integer (1) rather than string.
import zeus
file_list = []
i = 0
    myFile = open( str(output_dir+file_list[0]), 'w')
    count = zeus.get_line_count()
    mystr = zeus.get_line_text( 0, count )
    myFile.write( mystr  )
    myFile.close()
    zeus.WindowNext()
    i+=1
mgag
Script
Post by mgag »
Now this looks like a blog. The problem with zeus.get_line_text() is it doesn't like zero as an index. Starting with 1 works.
No need to answer previous posts. When I get stuck again I will post, and/or when I finish.
All the indexes used by the macro scripting functions are one based. I will update the help to make sure this is clear.
I am not overly familiar with Python but I don't think the get_line_text function will work the way you have it coded :?
When this function is called and more than one line is requested then the function returns multiple arguments.
For example the following Lua code use this function to get the first three lines of a file:
    file_line1, file_line2, file_line3 = get_line_text(1, 3)
    message_box(0, file_line1, count)
    message_box(0, file_line2, count)
    message_box(0, file_line3, count)
To work around this I would use the function in a for loop.
Here is my version of your macro:
import zeus
def key_macro():
    output_dir = "d:/temp/files/"
    file_list = []
    i = 0
        full_file_name = zeus.macro_tag("$FileName")
        zeus.debug_output(full_file_name)
        file_list.append(full_file_name)
        file_name = zeus.macro_tag("$file")
        new_file_name = output_dir + file_name
        zeus.debug_output(new_file_name)
        myFile = open(new_file_name, 'w')
        for i in range(1, count + 1):
            myFile.write(zeus.get_line_text(i))
            myFile.write("\n")
        myFile.close()
        zeus.WindowNext()
        i+=1
key_macro() # run the macro
mgag
Script
Post by mgag »
Thats precisely what I did.
Is there an API for a message box that gets some user input? In the zip file that gets created I want to include a notes file. I don't really want to open a new document - I think that would break up the flow of the macro. I would start with a Yes/No message box to ask user if they want to add a note, then I would open a message box for a note of ~100 characters - save that as a file that gets included into the zip file.
mgag
Script
Post by mgag »
I am confused about importing other modules in macros. I tried importing os and it fails; ImportError: No module named os
My python install is at c:\python25
See the user_input function.
I'll see if I can find out what is going wrong with the import.
mgag
Script
Post by mgag »
zeus.debug_output() doesn't seem to have the desired effect.
mgag
Script
Post by mgag »
Script is almost finished. I want to have two user inputs, but I am not doing something right. When I use two args I get None as the return value.
This is what I have, which works,
note = zeus.user_input("Note:", "")
This is what I want to do,
note = zeus.user_input("Note:", "","FileSuffix","")
But note is None. I would have expected a list.
Here is an example of how to use the debug output:
import zeus
def key_macro():
    # Debug output can be turned on using the 'Debug tools..' option
    # found in the General panel of the Options, Editor Options menu.
    # But this is an easier way to turn on debug output
    zeus.debug_enable()
    # Use the Macros, Macro Debug Output menu to see the output
    zeus.debug_output("this goes to the debug output...\n")
    zeus.screen_update()
This is a historical thing. The original user input dialog only ever returned one value.
But when the Lua scripting module was added, this function was extended to make use of Lua's feature of return mutiple values (i.e. see the get_line_text example shown earlier). So in a nutshell this feature will only work in Lua :(
It might be possible to extend this feature for the Python module, but since I don't do a lot of Python coding, I not even sure if something similar is even possible in Python :?
mgag
Archive Script
Post by mgag »
Here is the current version of the Archive Tabs Script.
import zeus
import datetime
# makes a zip file of all the open tabs. useful if you want to take
# a snapshot of the workspace very quickly.  Since it grabs all open tabs
# it makes an "atomic" backup (files are in "build" sync).
# The saved file is of the format: [prefix]YYYYMMDD_HH_MM_SS.zip
#   where: [prefix] = optional user input prefix
#        : YYYYMMDD_HH_MM_SS = Year, Month, Day, Hour, Minute, Second
def debug( str = ""):
    if 0:  # change to enable/disable debugging
        zeus.debug_enable()
        zeus.debug_output( str )
        zeus.debug_disable()
def key_macro():
    output_dir = "e:\\archive\\"         # path to archive directory here
    noteFile = output_dir + "note.txt"   # optional notes file name
    noteTextDefault = ""                 # a default value will force a note to be saved
    zipFilePrefix = ""                   # optional prefix for the zip file
    file_list = []
    # for each open tab, copy to the output_dir
    origTabWindowID = zeus.get_window_id()
    if origTabWindowID == -1:
        # there are no open windows
    while True:  # python version of a do while loop
        tabFileName = zeus.get_file_name().split("\\")[-1]
        # duplicate filenames will get a unique prefix
        if tabFileName in file_list:
            file_list.append( "%d_%s" % (len(file_list),tabFileName) )
        else:
            file_list.append( tabFileName )
        #create temporary copy of the tab file
        myFile = open( str(output_dir+file_list[-1]), 'w')
        debug( "%d file:%s lineCount = %d" % (len(file_list),file_list[-1], count) )
        for line in range(count):
            mystr = zeus.get_line_text(line+1) # 1-indexed
            myFile.write( mystr+"\n"  )
        myFile.close()
        zeus.WindowNext()
        if origTabWindowID == zeus.get_window_id():
            # we have looped around all the tabs - time to quit
            break
    # get user note to add to archive
    note = zeus.user_input("Note:", noteTextDefault)
    if note or noteTextDefault:
        myFile = open( noteFile, 'w')
        file_list.append(noteFile.split("\\")[-1])
        myFile.write( note+"\n"  )
        # could add a datetime stamp here, but already part of filename
        myFile.close()
    # build the zip command to archive the files
    zipFileName = zipFilePrefix + datetime.datetime.now().strftime("%Y%m%d_%X.zip ")
    zipFileName = zipFileName.replace(":","_") # fix invalid char ":"
    cmd = "zip " + zipFileName
    for name in file_list:
        cmd += name + " "
    debug(cmd)
    zeus.system(cmd, output_dir, 32+64)
    # now remove all the temp files
    cmd = "rm "
        cmd += name + " "
    debug(cmd)
    zeus.system(cmd, output_dir,32+64)
mgag
Post by mgag »
Yes, it is possible. Similiar to Lua it would seem. Might be nice to have more than two, make it arbitrary.
I tried importing os and it fails; ImportError: No module named os My python install is at c:\python25
I suspect this might be due to the fact that Zeus currently embeds Python 2.4 but I am not sure :?
As a test I created this script:
import sys
#import os
import zeus
def key_macro():
    zeus.FileNew()
    zeus.write("Executable: ", 0);
    zeus.write(sys.executable);
    zeus.write("\n\nModules: \n", 0);
    for name in sys.builtin_module_names:
        zeus.write(name + "\n", 0);
    zeus.write("\n\nKeys: \n", 0);
    for name in sys.modules.keys():
When run, this script produces the following data inside of Zeus:
Executable: d:\Projects\zeus3.96\zeus\Debug\zeus.exe
Modules:
__builtin__
__main__
_bisect
_codecs
_codecs_cn
_codecs_hk
_codecs_iso2022
_codecs_jp
_codecs_kr
_codecs_tw
_csv
_heapq
_hotshot
_locale
_multibytecodec
_random
_sre
_subprocess
_symtable
_weakref
_winreg
array
audioop
binascii
cPickle
cStringIO
cmath
collections
datetime
errno
exceptions
gc
imageop
imp
itertools
marshal
math
md5
mmap
msvcrt
nt
operator
parser
regex
rgbimg
sha
signal
strop
struct
sys
thread
time
xxsubtype
zipimport
Keys:
zipimport
zeus
__builtin__
sys
__main__
exceptions
And sure enough the os module is not in the list.
I suspect if you create a similar Python 2.5 script and ran it from the command line, you would get a different set of default modules.
