I am a new used to Zeus and want to use it for fortran coding.  This may be a dumb question but I cannot get my code to link by using the command line under the compiler options.
I am using Intel fortran and I can get the code to compile and link in a dos window.  I first have to execute the ifortvars.bat in the dos window but then it works fine.
The command line within the compiler in Zeus is:
c:\"Program Files"\intel\Compiler\Fortran\10.0.025\IA32\Bin\ifort $FN
The code compiles but then no linking to get an executable.
I am sure I am just missing something easy.
Kenny
						linking with intel fortran
Hi Kenny,
The good news is they can be configured quite easily by wrapping the setup batch file within a special compiler/link batch file
For example this is how I get Zeus to compile a c/c++ file using the MSVC++ compiler.
The MSVC++ compiler is similar in that for the compile and link to work the vsvars32.bat needs to be run first to setup the environment. Below is the batch file code that I use to make this work within Zeus.
Assume the following batch code lives in a file calle zcc.cmd and it is saved to the Zeus install directory:
Now to get Zeus to compile a MSVC c/c++ file all that needs to be done is set this batch file as the compiler option for the c/c++ document type as follows:
The $fn becomes the %1 variable of the batch file and the compiler errors are written to $fn.err error file. At the end of the batch file the errors file is then piped to standard output and hence will also be displayed inside of Zeus
So to make this work for your Fortran environment I would guess all you need do is change this batch file slightly.
Change these lines of the batch code:
to be something like this:
to these lines of batch code:
Where -options shown above represents any extra command line options that you may need to give the fortran compiler.
If there are no extra options then the command line should be something like:
To get the linker to work I would create a second linking batch file similar to the zcc.cmd above. You could then create a workspace for you Fortran project and add this linker batch file to the build options of the Workspace, Options menu.
One final hint is to use the Options, Editor Options menu and turn on the Debug tools, macros and executables option. With this option enabled Zeus will send the command lines to the Zeus debug output window.
When I have a DOS command line that is not working inside Zeus, what usually helps is copying the command from the Zeus debug window, opening a DOS prompt using the Zeus Tools, Dos Shell menu and then try running the command at the DOS prompt command line
													Compiler/linker environments that need a setup batch file to be run first can be a little more problematic to configureI first have to execute the ifortvars.bat in the dos window but then it works fine.
@echo off
rem Setup the build path details
call "c:\Program Files\Microsoft Visual Studio 8\Common7\Tools\vsvars32.bat"
rem Check for a temp folder (note: MSVC needs a temp folder)
if not exist d:\temp\ goto next1
set tmp=d:\temp
set temp=d:\temp
:next1
if not exist c:\temp\ goto next2
set tmp=c:\temp
set temp=c:\temp
:next2
rem Name a file to capture the errors
set ErrorFile=%1.err
rem Delete the error file if it exists
if exist %ErrorFile% del %ErrorFile%
rem Run the build
cl.exe -W4 %1 > %ErrorFile%
rem Display the error output
if exist %ErrorFile% type %ErrorFile%
rem Delete the error output file
if exist %ErrorFile% del %ErrorFile%Code: Select all
zcc.cmd $fn
call "c:\Program Files\Microsoft Visual Studio 8\Common7\Tools\vsvars32.bat"Code: Select all
call "c:\Program Files\intel\Compiler\Fortran\10.0.025\IA32\Bin\ifortvars.bat"Code: Select all
rem Run the build
cl.exe -W4 %1 > %ErrorFile%Code: Select all
rem Run the build
ifort.exe -options %1 > %ErrorFile%If there are no extra options then the command line should be something like:
rem Run the build
ifort.exe %1 > %ErrorFile%This may be a dumb question but I cannot get my code to link by using the command line under the compiler options.
						almost
This works in that it now compiles and links, except $FN is not recognized as a macro.  IFORT looks for a file with the name "$FN".
It works when I put the exact file name in place of the $FN in the batch program.
I have modified your batch program, and then I put the "C:\zeus\newbatch.cmd" in the command line under the compile tab.
Maybe I should it somewhere else? You mention a default document type.
So almost there. Is there a reason the $FN would not be recognized as zeus macro command?
That was a typing error on my part. I have corrected my post above with the correct information.
The %1 will also contain the exact file name.It works when I put the exact file name in place of the $FN in the batch program.
If you put the command in the compiler option of the fortran document type it means that when ever you use the compiler compile menu inside a fortran document the batch file will be used.Maybe I should it somewhere else? You mention a default document type.
If you put the command in the default document type it means that whenever you use the compiler, compile menu inside a document that does not define a compiler option or does not belong to a document type then this batch file will be used.
So the best place to put it is in the Fortran document type.
But the thrid options is to define a workspace and put the compile/build options there:
http://www.zeusedit.com/forum/viewtopic.php?t=33
Just my bad typing
