Setting of environment variables
Fonnieah
Post by Fonnieah »
Hi I am new to this and might have a stupid question for some of you. We currently use Microfocus Cobol but mainly use the editor and compile options, and are exploring other possibilities. My problem is this, if I try open include file nothing happens, I have set environment variable AlsoSearchInclude variable in settings/system/environment tab for both user and system (Not sure if this is the right place) Our copybooks also have a .COB extension witch is not included in the Copy instruction. Can anybody please put me on the right track?
Regards
Fonnieah
Post by Fonnieah »
Hi, just want to add, I also changed the Search Path in the Document type to f:\fdp550 (Where our copybooks lies) and get "No file was found in the current line" my copy statement looks as follows COPY CL1CMBRD.
Regards
I have created the Understanding View Open Include entry to explaain a little of how this Zeus feature works.
If you find this feature is still not working for your copybooks, please post a small snippet of you cobol code, containing the line of text that contains the copybook and also some information as to the directory structure of your files.
