Navigator Helper for Bison/Flexx
For more details refer to the comments section of the macro code shown below.
--        Name: Output Navigation Helper Macro
--    Language: Lua Macro
-- Description: This macro script tries to help with the navigation
--              from an import file to a corresponding line of a
--              matching output file.
--              To use the macro place the line of code in the input
--              file and the macro will try to locate the corresponding
--              line of code in the output file.
--              The output file is assumed to be tagged with input line
--              markers that use the [b]#line 10 "filename.l"[/b] format.
--        NOTE: The macro assumes the input files are bison (.y)
--              or flexx (.l) and the output files are C++ (.cpp).
function find_string(pattern)
    local line_current = 1
    local line_total = get_line_count()
    -- search the current file for the 'pattern'
    while line_current < line_total do
        -- get the line text
        local line_text = get_line_text(line_current)
        local len = string.len(line_text)
        if len > 0 then
            -- look for all todo lines
            if string.find(line_text, pattern) ~= nil then
                return line_current
        -- next line
        line_current = line_current + 1
    return -1
  if document > 0 then
    -- get the current file extension
    local extension = macro_tag("$ext")
    -- make sure it is a bison or flex file
    if (string.lower(extension) == ".y") or (string.lower(extension) == ".l") then
        -- get the current file name
        -- get the current line position
        local line_current = get_line_pos()
        -- this is the matching output .cpp file
        local output_file_name = macro_tag("$fdd$fb"..".cpp")
        -- try to open the file
        local result = file_open(output_file_name)
        if (result == 1) then
            -- build up a pattern
            local pattern = "#line " .. line_current .. " \"" .. file_name .. "\""
            -- look for an exact line match
            local line_found = find_string(pattern)
            if line_found == -1 then
                -- patten for the previous line
                line_current = line_current - 1
                -- look for an the previous line
                -- patten for the next line
                -- look for an the next line
--            message_box(1, pattern .. " " .. line_found, "Debug Information")
            if (line_found ~= -1) then
                -- move the cursor to the line found
                set_line_pos(line_found)
                -- some feedback
                message("Search Pattern '" .. pattern .. "' not found.")
                -- some feedback
            message("Error opening: '" .. output_file_name .. "' file.")
        message("This macro only works for document bison or flex files!")
