-- Name: Copy Fully Qualified Filename to Clipboard
-- Author: Jussi Jumppanen
-- Language: Lua Macro
-- Description: This Lua macro copies the fully qualified name
-- of the active document to the windows clipboard.
if document > 0 then
local file_name = macro_tag("$fn")
set_clipboard_text(file_name)
message("'" .. file_name .. "' text added to clipboard.")
-- Name: Copy File Drive and Directory to Clipboard
-- Description: This Lua macro copies the drive and directory
-- clipboard.
local file_name = macro_tag("$fdd")
-- Name: Copy File Name to Clipboard
-- Description: This Lua macro copies the file name of the
-- active document to the windows clipboard.
