Numbers Macro
Numbers Macro
Assume you have this piece of code:
    FieldXX
    FieldXX
    FieldXX
    FieldXX
    FieldXX
    FieldXX
    FieldXX
    FieldXX
    FieldXX
    FieldXX
    FieldXX
By column marking the XX values and running the Numbers.lua macro shown below the code gets changed to this:
    Field00
    Field01
    Field02
    Field03
    Field04
    Field05
    Field06
    Field07
    Field08
    Field09
    Field10
Here is the Numbers.lua macro source code:
--        Name: Numbers Macro
--    Language: Lua Macro
-- Description: This simple Lua macro will replace a column marked area
--              into a series of incremental numbers. To use the macro
--              column mark a range of lines and then run the macro.
--  How To Run: All Zeus macros can be run using the macro execute menu
--              item or they can be bound to the keyboard or they can
--              be attached to the macro drop down or popup menus.
  if is_marked() == 0 then
    message("This macro needs a column marked area.")
  -- the initial value
  local initial_value = "0"
  -- ask for a user supplied decimal number
  local value = user_input("Decimal Value:", initial_value)
  if string.len(value) == 0 then
    message("Operation cancelled by user!")
  local top   = get_marked_top()
  local range = get_marked_bottom() - top + 1
  -- disable screen updates
  -- delete the marked area
  MarkDeleteEx()
  -- convert the number to a character
  local offset = string.format("%d", value)
  -- maximum number
  local max_number = range - 1 + offset
  -- the maximum length
  local max_length = string.len(string.format("%s", max_number)) - 1
  -- comment the lines selected
  for i = 0, range - 1, 1 do
    -- build the number
    local number = string.format("%s", i + offset)
    -- save the current cursor
    cursor_save()
    for k = string.len(number), max_length, 1 do
      -- write out the padding
      write("0")
    -- write out the number
    write(number)
    -- restore cursor
    cursor_restore()
    -- move to the next line
    MoveLineDown()
  -- restore screen updates
