New File Create
gwgs
New File Create
Post by gwgs »
When called from the command line, either:
a). ask if new file to be created, or
b) don't create a 0 length file, and only create it when saved.
Can cause havoc when I mistype a filename to edit ;)
Grant Smith
Zeus already has this feature :)
Using the Options, Editor Options menu just check the File to open must exist option.
Now if you start Zeus at the command line with a non-existent file, a read only, non existent file will be created in Zeus. With the option unchecked a writable, zero length file will be created.
You can also convert the read only file into a writable file by using the File, Read Only menu and then using the File, Save menu ;)
