Previous post didn't seem to take so I'm trying again. Sorry if this ends up posted 2x.
This sequence fails every time.
set a bookmark
navigate somewhere else in same file and select a block of text
return to the bookmark via Control-B, etc
type and you return to and overwrite the selected block text
Jack
selected text and bookmark interaction
Hi Jack,
So I think it's working as designed
The reason this is happening is beacuse in the keyboard defintion Key press removes mark option is enable.This sequence fails every time.
set a bookmark
This might be the design, but it is very un-intuitive. I expected navigation via bookmarks to behave the same as navigation via cursor keys , unselect the text and then move the cursor.
I can live with this but I do see this as a bug ( whether it is a design or impementation bug).
Thanks for the quick response!
Jack
Jack
