rxSpencer - 3.96o
Phil Hansen
rxSpencer - 3.96o
Post by Phil Hansen »
Installed patch for 3.96o and now get errors when opening and saving files.
xTags debugging
Unexpected error opening tag file
Make sure rxSpencer.dll is located in path
Reverting back to 3.96h is fine.
Any help
Download one of the patches between the i an m versions and look for the rxSpencer.dll file.
Alternatively run the full version o installer in a new folder and copy cover the rxSpencer.dll file from that install.
Phil Hansen
Thanks. Problem solved
Cheers
Phil
