The macro below allows you to seamless reformat you current document from within Zeus:
-- Name: Astyle Code Reformating Macro
-- Language: Lua Macro
-- Description: This macro will excute the astyle.exe utility to reformat
-- the current file. For more details on how to use astyle.exe
-- visit the following web page:
-- http://guinness.cs.stevens-tech.edu/packages/astyle/astyle.html
-- NOTE: For this macro to work the astyle.exe must be in the
-- system path.
local locked = is_read_only()
-- macro only works for named documents.
local named = is_named()
if (locked == 1) or (document == 0) or (named == 0) then
-- can't run astyle.exe on current document
message("This macro only works for named document files!")
local dir = macro_tag("$fdd")
-- build uup the command line for the required styling
-- local cmd = "astyle.exe --style=java" .. " " .. file_name
local cmd = "astyle.exe --style=ansi" .. " " .. file_name
-- System control values
-- 1 - save the document before running the program
-- 2 - capture any standard output generated by the program
-- 4 - capture any standard error generated by the program
-- 8 - ask for additional arguments
-- 16 - the program will use the MS-DOS command interpreter (ie. dir *.* etc)
-- 32 - wait for the program to complete (the ESC key will cancel the wait)
-- run command using the 'save' and 'wait for complete' options
local flags = 1+32
-- run the astyle.exe command
if system(cmd, dir, flags) == 0 then
-- reload the newly styled docuemnt
FileReloadCurrent()
-- had problems running the command
local error_msg = cmd .. "\n\n" .. "Error executing astyle.exe command!"
message_box(1, error_msg)
To run the macro, save the above source to zScript/astyle.lua file, open a C/C++ or Java test file, use the Macros, Execute Script menu and type in [astyle.lua] and you should see the code reformatted.
