Search MSDN for a Keyword
This Zeus macro will search the MSDN for the word under the cursor:
'        Name: MSDN Macro
'      Author: Jussi Jumppanen
'    Language: VB Script Macro
' Description: This VB Script creates a Document Explorer object
'              to search the MSDN for the current word.
'  How To Run: All Zeus macros can be run using the macro execute menu
'              item or they can be bound to the keyboard or they can
'              be attached to the macro drop down or popup menus.
Dim oMSDN
Function key_macro()
  On Error Resume Next
  ' create the Document Explorer object
  'Set oMSDN = CreateObject("DExplore.AppObj.7")
  Set oMSDN = CreateObject("DExplore.AppObj")
  If Err.Number = 0 Then
    ' this macro only works for documents
    is_document = zeus.is_document()
    If is_document = 1 Then
      ' get the current word or the marked text
      word = zeus.macro_tag("$WEX")
      ' make sure we have a word
      If Len(word) > 0 Then
        ' See this keey for the collection details:
        '    HKEY_CURRENT_USER\Software\Microsoft\MSDN
        ' set the MSDN collection
        oMSDN.SetCollection "ms-help://MS.VSCC.v80", ""
        ' display the index panel
        oMSDN.Index
        ' search for the current word
        oMSDN.DisplayTopicFromKeyword word
      Else
        ' give some feedback to the user
        zeus.message "Place the cursor on word or mark some text."
      End If
    Else
      zeus.message "This script requires an one document or output window."
    End If
  Else
    ' Document Explorer not supported
    error_message = "The .NET Framework Document Explorer does not appear to be installed on this machine."
    ' display error message in the status bar
    zeus.message error_message
    MsgBox error_message
  End If
End Function
key_macro() 'run the macro
