As an example consider a case where "int" needs to be changed to "integer" for all c, cpp and h files found in the Zeus install directory. This is how it could be done:
(1) Make sure no files are open.
(2) Run the xfgrep utility using the Tools, DOS Command Line menu with these details
Arguments: xfgrep -d -f -n -l int *.c *.cpp *.h
Directory: $zd
(3) With the output window active use the Edit, Select All menu to highlight the xfgrep output.For a description of the xfgrep arguments run fgrep -? from the the Tools, DOS Command Line menu
In this case the $zd is used as the working directory. The $zd macro tag will expand out to be the Zeus install directory.
(4) Use View, Open Include menu to load the files for editing.
(5) Use the Edit, Replace menu to display the replace dialog and enter these details:The Open Include command normally searches the current line for a file name, but by selecting multiple lines it is possible to load several files at a time.
Find: int
Replace: integer
Match whole words checked
Match case sensitivity checked
All open documents yes
(6) Use the File, Save All menu to save the global changes made.The All open documents option runs the search an replace for all currently open files.
