Transfering Zeus Configuration.
I am retiring an old computer and breaking in a new one. I would like to run zeus on the new computer with all the configuration changes that I made on the old computer. How do I transfer the configuration.
If you go to the new installation and re-create an empty VHDL document type (ie entery nothing more than the file extensions section), you should notice a set of VHDL document type files created in the zConfig directory. Next just copy over your old VHDL files to replace these empty files.
But make sure the first file extension entered is consistent with the original files, as this file extension is used to name the configuration file.
The file pattern used for the document type files is ZeusXXX-YYYYYY.ext when the YYY is the first file extension and the YYYYYYY is the document type section.
