ctags with Fortran 90
E Programmer
Post by E Programmer »
I am writing Lahey Fortran code using standard Fortran 90
File extensions are .F90, but the code is an extension to Fortran 77 whose file extensions are .FOR
CTAGS is set to handle fortran code under the .FOR extension
I edited the environment variable to read
CTAGS=--langmap=fortran:+.f90
I can now run
ctags *.f90
at the DOS prompt and get a TAGS file.
However, if I
1) touch all the fortran files
2) delete TAGS
3) select menu item TAGS--UPDATE
Then
1) Zeus generate a xxx.zbi file
2) but no TAGS file.
I don't get an error from Zeus, there seems to be a pause and it returns.
If I leave the TAGS file generated manually in place, Zeus does not seem to be using it since none of the + signs appear (as they once did for a .for file).
If I look at a dump of the .zbi file, it has the subroutine names mixed in
If I look at the TAGS file, it has a nice sorted list of the subroutine names
Is there a way to see the ctags command line? I would hope it is something like what I gave above, or maybe a list of the files in the workspace.
Ideas?
The command line listed in the following posting:
http://www.zeusedit.com/forum/viewtopic.php?t=34
But you make the command line display by renaming the xtags.exe file. If Zeus has trouble running the tagger it will pop up an error dialog containing the command line run it tried to run.
But the problem is this case more likely than not related to the xtags.dll file :(
The xtags.dll takes the markers produced by ctags.exe maps them to Zeus browser items. These are the flags Zeus is expecting [/B]ctags.exe[/B] to produce for the Fortran file type:
// --fortran-types=[+|-]kinds
//         b  block data
//         c  common blocks
//         e  entry points
//         f  functions
//         i  interfaces
//         k  type components
//         l  labels
//         L  local and common block variables [off]
//         m  modules
//         n  namelists
//         p  programs
//         s  subroutines
//         t  derived types
//         v  module variables
And this is how the xtags.dll maps these ctags flags to the Zeus browser items:
switch (details.szKind.charAt(0))
        case 'b':
          type = Tag_Variable;
          break;
        case 'c':
          //-- distinguish forth class and fortran common
          type = (details.szKind.charAt(1) == 'l') ? Tag_Class : Tag_Import;
          break;
        case 'm':
          //-- distinguish forth method and fortran module
          type = (details.szKind.charAt(1) == 'e') ? Tag_Method : Tag_Package;
          break;
        case 'e':
        case 'f':
        case 'p':
        case 's':
          type = Tag_Function;
          break;
        case 'i':
          type = Tag_Interface;
          break;
        case 'k':
        case 'l':
        case 'C':
          type = Tag_Macro;
          break;
        case 't':
          type = Tag_Typedef;
          break;
        case 'v':
        case 'V':
          break;
      break;
If you post some sample fortran code to this post that contains some or all of these ctags flags I would be quite happy to take a closer look at the xtags.dll and see if it is at fault.
Then
You will never find a tags file. The reason is Zeus generates the tags into a temp file, copies the tags information into the zbi file and then deletes the temp file. The zbi file is browser information file for the entire project and contains the tags information for each and every file in that project.
The browser display is read from the the zbi file and not from any tags file.
I ran a simple test by adding a few simple fortran files to a project/workspace and at least for the tagging seemed to work fine. While the workspace was open the class browser was populated with the fortran function names and global variables.
