How do I configure Zeus to print line numbers in the left margin and print the file name in the top or bottom margin?
Thanks, Doug
Printing - line numbers and file name
Hi Doug,
To configure the printing use the Options, Editor Options menu and switch to the Print Setup panel.
In your case all you need do is check the Print Line Numbers option and in the Footer entry field add the $fn macro tag. You can you use any number of macro tags in either of these entry fields. For example somthing like $fn - $time<"HH:mm:ss tt"> will add the time the file was printed.
To change the printer font you need to use the Fonts panel and select Printer Ouput from the list of Display Views.
