Posts: 2655 Joined: Fri Aug 13, 2004 5:10 pm
Post
by jussij » Thu Jan 17, 2008 4:01 am
Here is a very nice file difference/merge tool and it's also free:
http://www.sourcegear.com/diffmerge/index.html
To run
DiffMerge from within Zeus use the
Options, Editor Options, Miscellaneous panel and add the following to the
Command line edit field:
"c:\Program Files\SourceGear\DiffMerge\DiffMerge.exe" "$f1" "$f2"
This allows you to run the tool from the Zeus
File, Difference menu dialog via the
View External button.
