SCC Revision Number
SCC Revision Number
I was wondering if I could change the default revision number 1.1 for SCC for a new file to a different number of my choice.
If you mean SCC in general then I think not, since I can not see any way to pass this information via the SCC SccAdd function
But if you mean Zeus SCC-CVS then this might well be possible
The Zeus SCC-CVS gives CVS an SCC interface by running a CVS command lines for the different SCC functions. So the real question is what would be the CVS command line that would be use to set the revision number for a file as it is added to version control
The current DLL can not be configured to do this
but a new version of the Zeus SCC-CVS has been created that should fix this problem
You will need backup the original zCvs/zCVS.dll, download the new dll from here and replace the older dll with this new version.
Next, use the Options, Editor Options menu and in the Source Control panel use the Advanced Scc Options button to bring up the Zeus SCC-CVS configuration dialog.
Use the About Button to make sure the version number is 1.95, then in the Global and Command Options section edit the Add Command Options adding -r 1.1 for the command line. Now when a file is added to version control it will be given an initial revision number of 1.1.
