Hello,
Just a simple request (hopefully), when you have two or more different files open at once you can press the Alt-N key on your keyboard to move between the different files or you can use your mouse to move between the files. But when you have a single file open and it is split into 2 parts you have to use the mouse or the Toggle Views (Icon on the toolbar) to move between the split windows. Is there some key stroke pattern that will invoke this Toggle Views action?
Mike
Moving between split windows
How do you do this?
Thank Jussi
But how do you bind the WindowViewNext and WindowViewPrevious keyboard functions to the keyboard?
I have done keyboard mapping but not binding.
Thanks Mike
Thanks Mike
Take a look at this keyboard macro example. For functions the procedure is even easier since you don't have to write a macro
