Using the doxygen utility it is possible to create HtmlHelp files for your own projects.
This is made even easier with the ability to run the doxygen build process from within the Zeus project/workpace.
For more information go here:
http://www.zeusedit.com/zoxygen.html
It is also possible to integrated the resulting help files into the Zeus Quick Help feature.
