Zeus VbScript and Variables
This very simple VbScript macro will display display the current line and cursor position in the message bar.
It shows how to assign a VbScript local variable to the value return by a Zeus built-in function:
Function key_macro()
    ' must have a document window
    if zeus.is_document() = 0 then Exit Function
    ' get current line position using the tag
    tag_line_num = zeus.macro_tag("$Line")
    line_num = zeus.get_line_pos()
    ' get current cursor position
    cursor_pos = zeus.get_cursor_pos()
    ' build up a message
    message = "Tag Line: " & tag_line_num & " Line: " & line_num & " Cursor: " & cursor_pos
    ' display message in status bar
    call zeus.message(message)
End Function
key_macro() 'run the macro
When run. the macro will display the current line and cursor position in the message section of the status bar and these details will match the line and cursor details shown on the right of the status bar.
Ed Grossheim
Using Jussi's answer: My Script to insert a Msg + Line No.
Post by Ed Grossheim »
6/26/2007 11:30:32 AM
My macro in vbs using Jussi's advice, which has the bonus of more info in the status box, to insert a Msgbox and Line number automatically in my Program via macro is as follows:
    call zeus.screen_update_disable
    call zeus.screen_update_enable
    call zeus.write("Msgbox " &Chr(34) &"This is line Number    "  &line_num & Chr(34) )
End Function
Works very nicely for me.
--- Ed
