HTML to WinHelp Utility
Here you will find links to HtmlHelp and WinHelp files that will work with the Zeus QuickHelp feature.
Locked
The html2hlp utility can be found here:
http://javadocs.planetmirror.com/htmltohlpe.html
For example the html2hlp utility could be used to convert JavaDoc HTML into a JavaDoc CHM file and the resulting CHM file then configure to work with the Zeus Quick Help.
Locked
