Close Window
qbert
Close Window
Post by qbert »
I use Ctrl-W to close windows on almost every application on windows, can you add an alias or change Ctrl-- to Ctrl-W ?
Yes you can :)
Use the Options, Editor Options menu, switch to the Keyboard section, edit the active keyboard mapping and bind Ctrl-W to the FileClose function ;)
