undo of folded code
msek
undo of folded code
Post by msek »
Let me just to point out. I'm afraid this is a real bug (v3.96b), not the register or installation problem.
There is not expected behavior of 'Undo' when (e.g. by chance) one make a change in folded code (at the first visible line). The change is automatically applied to every folded line. This is not nice but somehow understandable (wrong step - not nice consequences). The problem arises when to undo such accidental change before you unfold the block. 'Undo' works like there were no folded code changing the following lines. More, there is no possibility to 'Redo' the 'Undo'.
br.
This will be fixed in the next Zeus patch due out shortly.
The code will be changed to make the folded lines read only so that they can not be changed accidentally ;)
This bug is fixed in the latest Zeus patch: http://www.zeusedit.com/forum/viewtopic.php?t=1064
All folded lines are now traeated as read only in terms of user input.
