For example consider the following mapping.txt text file which maps a key word to a string value:
return {
-- Key Value
["for"] = "for (int i = 0; i < 100; ++ 1)\n{\n}",
["do"] = "do\n{\n}\nwhile(i < 0);",
["if"] = "if ()\n{\n}",
function table_list(key_values)
list = ""
-- build up a list of the keys in the table
for key, value in key_values do
list = list .. key .. "\n"
return list
local locked = is_read_only()
message("This macro can only be run with a writable document file.")
-- the default key value
local nill = ""
-- ask for a user for a key value
local key_value = user_input("Key Value:", nill)
local result = string.len(key_value)
if result > 0 then
-- load the key mapping
key_values = dofile("mapping.txt")
-- use the key to look for the result
result = key_values[key_value]
-- see if anything was found
if result ~= nil then
-- print the result found
print(result)
message_box(1, "The key: " .. key_value .. "\n\nwas not found in key list:\n\n" .. table_list(key_values), "Key Not Found")
message("Operation canelled by user.")
