get_marked_left() does not return 1
dmaon
Post by dmaon »
Here is the description how to recreate the bug:
1) Move the cursor to a column that is not the first one on the line
2) Press alt-L to mark the line
3) Press the down arrow to mark a second line and stay in the same column in the line that is not the first column
4) Press a key that activates a macro that tells you the value returned by get_marked_left(). You will get the column number where the cursor is standing and not 1
I am sure that I am working with the lates version as we bought our copies just a week ago and downloaded the latest version.
By the way - you did not respond to my folding problem. Did you get it and understood it?
David
Thanks for that. I can now see what you mean :)
For the mean time I would suggest the following work around:
function my_get_marked_left()
    left = get_marked_left()
    -- check for the Zeus line marking bug
    if (is_marked() == 1 and get_marked_mode() == 1) then
        left = 1
    return left
    message("Zeus left is: " .. get_marked_left() .. " my left is:" .. my_get_marked_left())
This problem was closed just today ;)
See the folding section for the details.
